Philips DVD963SA & PAL Progressive
Discussion in 'Projectors, Screens & Video Processors' started by Dimmy, Jan 23, 2003.
  1. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I've JUST bought a Toshiba 28ZD26P Progressive Scan compatible television, although as I'm sure most of you are aware it only supports NTSC Progressive. I've heard that the aforementioned DVD player can support PAL progressive by converting it to an NTSC signal, which obviously means I can have PAL progressive on my nice new Toshiba telly. But the thing is, after an hour's searching, I can't find the DVD deck anywhere on the net for purchase! Could somebody please tell me where I can buy it from, as I'd really like the option of PAL Progressive. Merci Beacoup
  2. saguk
    saguk
    Aug 5, 2002
    444
  3. Turl
    Turl
  4. metssuru
    metssuru
    I am a newbie to home cinema but im very interested in progressive scan. I have just orderer a philips 963SA and im now looking for a tv to match it.
    Have you tried using your toshiba 28zd26p with it for pal progressive and does it work?
  5. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I didn't buy the philips in the end - as is said underneth, I opted for the Toshiba. Mainly because it'd been recuded by like a grand and I didn't want to miss out on the offer. The 900E however does the same thing as the 963SA in that it converts PAL Progressive to NTSC signals, which does work with the 28ZD26.
  6. churchwa
    churchwa
    When you say it converts it to NTSC, that is not to say that it has to. I assume that it can output pure Pal progresive scan?
  7. mwj666
    mwj666
    I've also been looking at the Philips DVD963SA - for progressive on component video to go with my nice new plasma screen...
    BAD news: As supplied, the 963SA is only configured to do progressive scan on NTSC discs, not PAL ones. As region 2 discs are PAL, this makes progressive playback ability pretty useless in the UK unless you get it multi-regioned and have USA discs.
    GOOD news: I have been told that the player is inherently capable of PAL progressive playback and that if you ring Philips they will give you a code to enter to activate this facility.
    I have also found a 'remote hack' which is supposed to activate PAL progressive playback. I don't have the details to hand but if anyone wants to email me I'll let them have it - subject to the proviso that I haven't tried this myself and accept NO LIABILITY WHATEVER for any deleterious effects it may have!
    Martin
  8. IanM
    IanM
    Dec 17, 2002
    160
    +5
