Philips DVD963 PAL Prog Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by BoG, Jan 23, 2003.
  1. BoG
    BoG
    I am considering buying the Philips DVD963SA because it has progressive scan capability. I have seen the remote PAL progressive hack - has anybody done this successfully or had problems with it?
    I am not interested in MR capability but I do want to play R2 discs using PAL progressive to my projector.
  2. widescreen
    widescreen
    Jan 18, 2002
    81
    11
    North Wales
    +4
    The hack is simple. On the remote press "PLAY 159 222 023 00 PLAY"
    Then just change the picture options for progressive (new option appears) to unprocessed.
    That's all!
  3. zoro
    zoro
    Jan 23, 2003
    326
    +7
    is this hack for US player/r1 player?
  4. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    In the latest firmware version Pal P is enabled out the box.
    7.11.1
    If you get a player with an older firmware you can download the updated one and burn to cdr then upgrade.
  5. zoro
    zoro
    Jan 23, 2003
    326
    +7
    Is this number suggest, serial number, model number or firmware?
    Pls. explain?JSW!
  6. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Firmware number.
  7. Kamui
    Kamui
    Dec 10, 2002
    80
    Chesterfield
    How you finding the 963sa JSW? Is it worth money as im wanting something to replace my crappy old samsung 709 £249 when i first bought it would you believe :D
  8. Sparky101
    Sparky101
    Nov 17, 2002
    283
    +18
    Can you point us to where the firmware can be downloaded from? I've search Philips web site and can find no mention of it. Cheers.
  9. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Right click Here and choose save target as
    Instructions for burning cd Here
    All the above has come from this Thread at AVS.
    Bry
  10. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    On that AVS forum post they also seem to be posting about problems with lip sync on playback of R2 discs using YUV PAL Prog Scan output.
    Has anybody experienced any lip sync problems using their PAL Prog Scan hacked 963SA with R2 discs ?
    looks from the on line manual that you can delay audio on the player. How many milliseconds can you go to ?
  11. meisha
    meisha
    Sep 4, 2009
    I have the r1 version of this player. Will this simple hack make my player able to play PAL DVDs from the UK? Thank you in advance! :) I've been searching and searching and it seems all the hacks are referring to r2 or other players, not r1, but I could be misunderstanding.
