Philips DVD-R75 Firmware Upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by LRaybould, Aug 28, 2004.
  1. LRaybould
    LRaybould
    I have a Philips DVD-R75 Multi-Region DVD Recorder purchased from Richer Sounds back in December last year.
    If I were to update the firmware of the player, would this disable the multi-region function of the player?
    Would appreciate some advice
    Lawrence
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
    Are you having problems? If your not and all is working as it should and it is reading the media you need it to read then by updating the firmware all you do is run the risk of introducing some of the errors that others have seen after attempting such an update: i.e. locked machines and disk errors.
  3. JefUK
    JefUK
    Mar 31, 2002
    440
    28
    +52
    Updating the firmware does not normally disable the multi-region feature.
    I have updated the firmware on my multi-region DVDR80 4 times with no problems, and 2 other recorders several times, again with no problems.
