Philips DVD blanks and Philips DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by david park, Jan 13, 2005.
  1. david park
    david park
    Got a pack of 10 Philips brand DVD blanks DVD+RW yesturday at Currys good value at £9-99.
    There is a warning on packet to see the enclosed leaflet on upgrading before use. There is NO leaflet.
    Also a web site to look at www.DVDRWservices.com
    there is no such site.
    First time I've seen such a note on other brands nothing.
    Anyone know about upgrading the DVD recorder in order to use Philips brand?
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Some of the older Philips machines will not recognise the faster rated +RWs. If they are rated 1-4x (as I think those Philips discs are) then they should be OK to use straight off. If they are just 4x, then you may need a firmware upgrade for the recorder.
    You can have a look at the DVDplusRW.org website, and do a search for your Philips recorder and the most recent firmware upgrades (which will be on the Philips website). Be warned that upgrading the firmware is not always straightforward, and some would advise against it unless you really need to.
    What model is yours, BTW, and when did you buy it?
  3. david park
    david park
    It is a Philips DVDR70 bought last year.
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Do you know how to get the machine to display the firmware version..? If so, can you let us know what it is..
  5. david park
    david park
    Looks like it is on a secret menu, as I can't see that on visible menus.
  6. david park
    david park
    Right now got lots of numbers for you, I've no clue as to whats what.
    (C) Philips 1999-2003
    D1 E2 24258 AN 130303 SV70
    BE 20.3.23 DV not present FP 13
    P1_7_b 20031213_1030 dev alead 5.16
    BASE_20031211_LF16d 20031211_1257vp
  7. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    You have ff16d firmware (bottom line of text, in the middle). Not the most up-to-date, but I would be happy with that version if it were my machine.
    A distillation of the experiences on the DVDplusRW forum is that this firmware should certainly be able to accomodate the use of 4x discs, so it shouldn't matter whether they are 1-4x or just 4x.
    Seeing as they are Philips discs, you should go ahead and use them. Let us know how you get on...
  8. david park
    david park
    Tried one today and it worked fine.
    Many thanks for your help.
