Philips DVD-962SA query
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chris-L, Jul 2, 2002.
  1. Chris-L
    Chris-L
    Could someone please help with a query?
    I am thinking of buying a Philips DVD-962SA, but have been put off by the talk of the forthcoming 963SA. Does anyone know much about this new model?
    Am I right in assuming that the 963SA will be a more expensive prog. scan model for the UK market? If this was the case, the 962SA would suffice as I don't require prog. scan. If however the 963SA was a similar priced improvement, I would hold on.
    While on the subject of the 962SA - does anyone know where you can get hold of a chipped version, other than Techtronics?
    Any advice would be most welcome - Chris.
