Philips DVD 711
Discussion in 'Blu-ray & DVD Players & Recorders' started by Quzac, Apr 25, 2002.
  1. Quzac
    Quzac
    If I make my dvd player (philips dvd 711 R2) region free, will I then be able to play all R1 movies.
    Is there any posibility to make it region choise, so I can choose the region I want it to play?:confused:
  2. DaveP
    DaveP
    I'm not sure why you'd want this feature! I had the 711 and when I put a Region1 in it played it, when I put a Region 2 in it played that too.
    DaveP
  3. Quzac
    Quzac
    That's why I ask, so I can get replies to learn more about my dvd player. Thank you for giving me that reply. Can you also tell me how to make it region free, hopefully without a one4all remote! Is it possible to do it only with the original remote?
  4. DaveP
    DaveP
    It can only be done with a one4all afaik. It needs a special code to get into the setup.
    Buy one from Argos and return it for a refund after you have changed the code!
    DaveP
