Philips DTR 1500 No Freeview from RF out.
Discussion in 'Freeview & YouView' started by pwiles1968, Oct 11, 2003.
  1. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    I have just put a Philips DTR 1500 in for my father in law, no problems picked up all channels expected even in a weak signal area with great picture out of the Scart, the RF channels were being looped through but there was no Freeview signal from the RF out. This is not important for the Telly downstairs but I had intending hooking it up so he could watch the Freeview signal upstairs if he wanted to, I could see no option anywhere to turn this on, is this a problem with the box :confused: , or are Phillips being cheap and not putting an RF modulator in the box. :thumbsdow
    If there is no RF modulator in this box what other boxes are available that have this facility? :smashin:
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,186
    +3,037
    I have the same box and it is impressive. I don't use the RF connection (scart connection to a DVD recorder), but according to the spec it has full range RF loopthough.
    In the installation menu you allocate the RF to a channel, mine is set to 45. I then assume you just tune the TV/VCR to the 45 channel and get freeview.
    Is that what you need?
  3. phenom2003
    phenom2003
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,186
    +3,037
    So what does the RF modulator do?
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    It modulates the video and audio output of a STB and allocates it a RF frequency and then sends it out of the RF socket. This allows you to not only have the TV tuned into the five analogue channels but also a sixth which carries the STB specific output, otherwise you can only watch the STB output via scart/s-video or composite phonos.
    The Philips only has RF loopthrough which means that RF analogue channels that are present on the input signal are also present on the output signal but you can not output the STB specific output via RF.
  6. bobones
    bobones
    Jan 15, 2002
    453
    +7
    If you connect the Philips to a VCR via the vcr scart, then the freeview signal will be available via the VCR's RF out.
  7. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    This assumes you have a video with an RF modulator.
  8. bobones
    bobones
    Jan 15, 2002
    453
    +7
    What do you mean? Are you saying this VCR doesn't have a scart socket that can be output via the RF out by setting the VCR's tuner to the external input? I would have thought just about any VCR less than 10 years old would have this capability.
  9. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    This vcr does not even have the ability to record via the main scart! do not know how old it is, the scart 2 is a satellite control something or outer, I have told them to buy a new VCR.
  10. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    I sent an enquiry to Philips about this problem via the web site and received the obligatory reply saying it is being processed and someone would get back in 2 days, which was a month ago but still nothing despite a reminder. Recently they actually had the cheek to send me a questionnaire to ask how the service I received was, the responses obviously were not favourable. I do hate poor customer service.:mad:
  11. Fernsehman
    Fernsehman
    I guess they probably feel it's not worth answering. If you buy something which specifies "RF loopthrough" but no "RF modulator" you can't expect it to have an RF modulator.
    It's like buying a base-model car then complaining it doesn't have ABS, traction control, heated leather seats or whatever. The dealer just thinks you are taking the p;ss.
  12. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    It does not say in the specification 'No RF Modulator', If it did I would know there was no modulator and would not have asked the question.
    A car specification may not say it has a radio but in current times you would expect a radio in your car!
