Philips DTR 1500 fault help please?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Adam_Lee25, Aug 8, 2005.
  1. Adam_Lee25
    Adam_Lee25
    Aug 8, 2005
    5
    Manchester
    My Philips DTR 1500 recently just stopped working and now all I get is a blank screen and the two LED's on the front of the freeview box seem to flash out some kind of fault code.
    The light sequence Im getting is: - Right hand LED on for a couple of seconds followed by a quick succession of maybe 30 flashes then both LED's are lit red for a couple of seconds before the sequence repeats itself.
    I’ve tried leaving it plugged in for days in case it was trying to update? I’ve Tried holding the low power button for 5 seconds to reset the box and I’ve even tried holding the + button whilst reconnecting the power. But nothing seems to help? Does anyone know what’s wrong with it? how to fix it? or has suffered the same fate and binned the unit?
    Any help would be most appreciated.
    Regards
    Adam
  2. Adam_Lee25
    Adam_Lee25
    Aug 8, 2005
    5
    Manchester
  3. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    I have the 1500 but it's been a faultless performer, couldn't even say where the manual is now:)
    Try the DTT forum over at DS, you may find what you are looking for.
  4. hanxslf
    hanxslf
    Oct 12, 2003
    153
    north yorkshire
    +4
    restore ''virgin mode'',as new out of box.
    try this mate,
    disconect power,
    keep pressing '+' button while connecting power,
    led will start to blink orange while red led remains on,
    release the '+' button.
    briefly press the '+' button.red led is still on and the multicoloured led is blinking red.
    enter code with remote 9900
    once entered,multicoloured led is green.in case of a bad code led stays red
    wait untill the receiver re starts by displaying the first install wizard.
    good look mate. this is taken from my dtr1500 manual and it worked on my own box
  5. Adam_Lee25
    Adam_Lee25
    Aug 8, 2005
    5
    Manchester
    Thanks for your help chaps but non of that seems to work. Its just fecked I think. I bought another philips one from argos for £45 from argos instead. I guess Ill just bin it. Shame really it seems a waste :(
