Philips Cordless RF Rear Speaker's.
Discussion in 'Home Cinema Speakers' started by MURFER, Dec 10, 2002.
  1. MURFER
    MURFER
    I have these speakers that are connected to My Philips TV.
    Would It make a big difference to buy a good speaker cable to wire these up to one another or should I just stick with the cheapo cable that came with them???
    Will I notice any difference as I do get quite a bit of buzzing but thats done to the RF side right??
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,905
    71
    50 Rue St Georges, Paris.
    +32
    The supplied speaker cable is fine for it's purpose.
    The buzzing should not be too noticeable, have yours checked by your supplying dealer under warranty.
