im thinking of getting philips 42 9966c gets good reviews, has pixelplus 2 tec. dnm everything my crt telly has my problem is the contrast ratio 1000.1 i thought that the tvs with low con ratio were supposed to be poor quality the fullspec is below but@£2K i thought this was a good buy until i saw the ratio any advice please Aspect ratio : 16:9 Brightness : 1000 Contrast ratio : 1000:1 Diagonal screen size (inch) : 42 inch Diagonal screen size (metric) : 107 cm Visible diagonal screen size : 107 cm Display screen type : HD plasma panel Picture enhancement : Active Control & Light sensor, Digital Crystal Clear, Digital Natural Motion, Jagged line suppression, Movie plus, Pixel Plus II, Progressive scan, Widescreen plus, 3D combfilter Screen enhancements : Anti ageing circuit, Anti reflection coated screen Viewing Angle (Horizontal) : 160 degree Viewing angle (Vertical) : 160 degree Panel resolution : 1024 x 1024i
anyone one care to help me is this a poor set to choose cause of the contrast ratio help please im about to buy and have 2.5k to spend
Contrast is very good. Had to put everything to 50%, because it was to much. Other systems saying a contract of 5000:1 have less contrast then this one. Don't believe all the numbers you read. Lem
I wouldn't place much faith in contrast ratio figures quoted by the manufacturer as there is no standard (or agreed) method to arriving at a quoted figure. Get a demo of the set that you are interested in and let your eyes decide for you. If you then like it, go for it. Whilst the Philips LCD screens gain much favour in the LCD section. The Philips plasma devotees are few and far between in the plasma section here. Most people here will steer you towards Panasonic or Pioneer. I see from the quoted specs that the glass in the Philips is ALiS (try a forum search) and to be honest, I've never seen anyone complain about ALiS panels because of poor contrast ratio. People either seem to love them or hate them though. S.
