Philips Blu Ray Bdp2700/05 -MKV?
meat
Just got this unit from Adsa:
Philips Blu Ray Bdp2700/05 | Blu-ray Player | ASDA direct
I was hoping it would play mkv files but no luck, even if I change the mkv extension to avi, which was suggested for a different Philips model in another thread. Will Philips be likely to issue a software update to enable this in the future or as I suspect will I have to change it for a more expensive model. By the way,the upscaling capabilities to my eyes looks great. Any advice much appreciated.
Thanks.
wilx01
Thanks.
Got 2 today from asda £57. Both play MKVs fine, from USB and DVD discs
Zaim7890
How did you get yours to work, i just got the same player and it won't play MKV's, used my flash drive.
Janneman
For those who has problems with the Philips BDP2700/12 or BDP2700/05 MKV or other files see:
Supported Audio:
Supported Video:
I Use Firmware version 1.54 and it works like a charm :)
https://www.p4c.philips.com/files/b/bdp2700_12/bdp2700_12_fus_eng.zip
