Philips and the law
Discussion in 'TVs' started by davidgirecourt, Nov 2, 2004.
  1. davidgirecourt
    davidgirecourt
    Hi all
    My 32PW9527 need a new tube. I bought it from new (with 1 year warrany) in November 2002 and the first tube was changed under warranty in November 2003 for £428.
    It now needs a new tube again and I would like to know where I legally stand.
    Thanks in advance for your help.
    David :suicide:
  2. mr ooops
    mr ooops
    Mar 4, 2003
    3,592
    103
    Hardwicke and Wotton
    +353
    here is a quote from the trading standards website, it concerns a fridge freezer, but the same is true for a telly too, and as u have already had a tube replaced and its already gone again i reckon you have a good argument
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    David,
    I'm not a Lawyer (if only :laugh: ), but the above sounds right to me.
    However, the replacement tube should carry a 12 month guarantee so, if you're quick, I think you stand a good chance of a second claim.
    Good luck. :thumbsup:
  4. nig28
    nig28
    I
    I have a little experience with televisions and I find that most of the good companies will help with some or all of repair costs within 2 years. But onceyou have had it repaired it does not extend the warranty.
    The ammount of help you get depends on the type of fault and how persuvive you are.
    Nigel
  5. davidgirecourt
    davidgirecourt
    Thanks for your answers.
    I will dig towards trading standard a bit more for a start. Also, the same company which diagnosed the tube again says that the new tube they fitted nearly a year ago only has a 3 months warranty "but they will check".
    For sure this one isn't gonna go away and someone (not me) will pay for the repair.
    David
