Hi all,
I have a 65OLED706 and I am having a similar issue though not the same. I'm using some Hue Play bars and the bars are suffering from the stupid dim white light. Philips technical support are useless and advising that there is no issue.
"Thank you for contacting Philips.
From our end we can not assist you further with your case, we would consider this to be within specifications
The TV is communicating the same color information to the Hue lamps that it's internally using to feed the AL driver, how the Hue lamps will respond to these values is entirely up to the Hue implementation.
Technically, the TV is not sending an "off" command to the Hue lamps, but an RGB value of 0x00 (zero on all channels), if this corresponds to "off" or "vague white with low duty cycle" is up to the Hue implementation"
There's definitely an issue with the TV. I've connected the bars up on the Hue sync windows app and works flawlessly.
Why are Philips so useless and burying their head acting like there is no issue. I feel like the technical team don't even have the TV or have used it with an Oled to even know how much of an eyesore this is.
Pic attached.
I see some people mentioned an update that may fix this, which is contrary to what Philips told me and now won't open any further tickets for me on the issue.
Useless.
Pic attached.
Useless.
