L
LCD User
Just got my 9986 back from the firmware update and set it up using DVI connection to component cable. Sound through the coaxial is great, however even with prog scan on the DVD the picture I am getting is all redish/purple!
Can anyone suggest the solution to this prob? I have checked the DVI cable on a projector and it works. Is this a problem with the LCD recieving the signal through the component connection from the DVD or are mt connections through the amp (which I've changed multiple times) the problem?
Frustrated
J
Frustrated
J
