Philips 9976, has anybody tried to price match John Lewis
Discussion in 'Philips TVs Forum' started by clarkem1, Mar 21, 2005.
Tags:
  1. clarkem1
    clarkem1
    Seems that this tv is a good price on net, but JL has a 5 year warranty, nybody tried price matching, and if so which ompanies would be best to price match agaist, thanks in advance
  2. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    JL will only price match against a online company that also has a Bricks and Mortar store where the TV is on Display and price marked, they dont price match against online only, they don't normally limit you to local area etc, I got a RDXS32 price matched at Cribbs in Bristol against Sound And Vision in Bolton saved nearly £206 compared to JL's price of £599, if you do a search for John Lewis, it should bring up some threads with shops that thye will price match against.
    Taz
  3. BADA55
    BADA55
    Mar 16, 2005
    233
    +3
    Yeah JL require any retail store to have the same product actually in stock and not just on display.
  4. clarkem1
    clarkem1
    Just got confirmation from Jl that they will price match this tv, at £1,447 (inc delivery), what would be best leads to get for Jamo DVD and Sony Sky box, any thoughts appreciated - and are there any problems i should know about.
    thanks
  5. sgiorgi
    sgiorgi
    Was this the JL website that said they would pricematch an online price or a JL shop. If a JL shop which one as I am looking to by a 9976 shortly and also want the benefit of their 5 year guarantee.
  6. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Stotting TV! Good choice...
    Will the Jamo be able to deliver Progressive Scan signals? If so then you'll need a Component lead to connect to the Component/VGA/DVI adapter. If not, then you'll need a couple of good Scarts for it and the Sony. www.tvcables.co.uk
    These guys will do you really good cables at silly cheap prices. The £5.99 scarts are wonderful!
    Jimmy
  7. clarkem1
    clarkem1
    Rang JL in Bristol, pricematched video & tv direct, they have one shop in Bolton, they came back to me the same afternoon, looks a good deal if it is similar to 9986, albeit without pp2 and ambilight.
  8. clarkem1
    clarkem1
    jamo has progressive scan, only thing i can see is that 9976 (and 9986) do not have component, presume scart with rgb as good?
  9. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    I think you will find that they do have Component but you need the adapter that comes with the TV's to go through the DVI input, someone will correct me if I am wrong, pretty sure thats the way it happens on the 9986 anyway,
    Taz
  10. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Yeah, the 9986 and the 9976 come with an adapter that allows you to connect Component through the DVI connector. Bit clumsy, but it works very well. This accepts Progressive Scan and produces amazing pictures...
    Jimmy
