Philips 963sa stock
Discussion in 'Blu-ray & DVD Players & Recorders' started by mccune, Jan 16, 2003.
  1. mccune
    mccune
    i am trying in vain to locate one of these players but to no avail. anyone know if there is anyone out there with these in stock?
    many thanks:D
  2. TimF
    TimF
    Best thing is to choose a supplier and wait for stock - No dealer seems to be able to carry any stock.
    I have waiting for about a fortnight for mine and I might get one in about 10 days or so.
    Try Unbeatable or Robertsons etc - None of the major High street suppliers have em listed
  3. Jonny1973
    Jonny1973
  4. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Let us know how you get on with the 963 and the Panny, ie
    what it reports the signal type for ntsc/pal prog scan
    I'm in the middle of trying to track down a 963 for myself.....
  5. Jonny1973
    Jonny1973
    I heard that due to short demand dealers are not allowed to stock them.
    They have to provide proof of orders to Philips before Philips will send them any players.
    Robertson's get a delivery from Philips once a week (Thursdays).
  6. jamesl01
    jamesl01
    Hi Jonny
    Did your 963 arrive today? If so what do you thnk of it?
    Mine didn't arrive today so am hoping it will be here next week.
    James
  7. Jonny1973
    Jonny1973
    Picture is almost HCPC quality. PAL is reported as being 625P and NTSC 525P from my AE100.
  8. Jonny1973
    Jonny1973
    Hi James,
    Happy as Larry so far. The picture is great much better than S-Vid, component or my Pro-V but not quite PC perfection but pretty close.
    The hacks were a bit fiddly (instructions not clear) but both worked. Theres an interlaced/progressive switch on the back of the player which i hadn't seen. Doh!!
  9. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Jonny,
    thanks for getting back....I've ordered a 963, they should
    have it in 1 week so hopefully not long after that i'll have it.
    Already using component from Sony 725 player so really looking
    forward to see if the progressive makes a big difference and
    I read on here that one owner found the onboard decoder to
    be better than his Yamaha amp so I will be trying that out with my Sony 925.....might aswell use them if they're better...
    Ger
  10. widescreen
    widescreen
    Jan 18, 2002
    78
    North Wales
    +3
    Got mine today from unbeatable.co.uk, took about a week - impressive service.
    I've got a problem with trying to do the region hack, the 963SA isn't responding with signals sent from my Palm Tungsten with OmniRemote, RC6 code or any Philips DVD remote code isn't working. I've tried Omni with a Sony TV and that works.
    I'm going to try and borrow a different Palm and see if that helps. Has anybody managed to do the region hack with a Palm on the 963SA?
    PAL Progressive hack worked well but that only uses the player's remote anyway.
  11. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    I did my region hack with a basic clie (with normal IR). Needed to be very close (like 1cm) away from the IR receiver on the DVD player, but it was fine. You get the dashes up, then input the code numbers on your philips remote.
  12. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Do the 'dashes' appear on the display on the actual player itself, or on the TV screen the player is connected to ??
  13. widescreen
    widescreen
    Jan 18, 2002
    78
    North Wales
    +3
    I managed to do the hack using an Allinone remote, that I had lying around.
    First impressions of the 963SA are excellent. Image quality is great, the usual rich colours we expect from the recent Philips players. Deinterlacing is of course great with the SAGE chipset but I noticed bad shimering and edge enhancement in progressive mode particular with text. I didn't see this in interlaced mode so then checked the "progressive only" settings and noticed the "True Life" default setting was at +3, after setting this to 0 it removed the edge enhancement and shimmering problem.
    The major thing, at least for me, is that there is NO Chroma Bug, or at least the SAGE chipset hides it so well it isn't noticeable.
    The only disappointment so far is the response of the player to the remote control, you need to point the remote directly at the player for it to respond, bouncing off walls doesn't work so well. I'm going to have to rearrange my HIFI.
    Well, I've been searching the last 3 years for a player like this, after spending a lot of money on various players, and can't believe what a bargain this player is - £310 from unbeatable.co.uk
  14. widescreen
    widescreen
    Jan 18, 2002
    78
    North Wales
    +3
    They appear on the player itself. I put the player into stop mode without a DVD inside when doing the hack, don't know if this makes any difference though.
  15. Klippie
    Klippie
    Dec 1, 2002
    628
    Scotland
    +58
    widescreen,
    Great info on the 963SA, could you answer me a few questions.
    Now that you have it set up properly is it completely free from shimmering and jaggie lines on sharp moving defined edges as this is very important to me before I decide to buy as I was considering spending double this to get a player that displays a clean smooth image.
    How does the picture compare between interlaced and pal progressive ?
    Are you using it on a TV or a projector ?
    Cheers Klippie.
  16. widescreen
    widescreen
    Jan 18, 2002
    78
    North Wales
    +3
    Klippie,
    Yes, the jaggies and shimmering are gone - just a nice smooth image now. :D After tuning the DVD player and my projector the picture is now excellent - I'm extremely happy with it.
    Differences between interlaced and progressive are subjective due to the quality differences of your projector/TV's deinterlacer. They aren't really noticeable on my system due to my projector having a great deinterlacer - but I needed the progressive output due to lipsync issues with my projector.
    I guess you may be talking about the Denon 3800 which I was also seriously considering but the 963SA does pretty much everything that can with just as good image quality. Although the Denon is known to have very fast speeds for menus and chapter changes.
  17. Klippie
    Klippie
    Dec 1, 2002
    628
    Scotland
    +58
    widescreen
    Your feedback has just saved me £400!
    Thanks very much....
    Klippie.
