Philips 963 SA - Prog. Scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by TimF, Jan 27, 2003.
  1. TimF
    TimF
    Bit of a lame question - But how do you know if you are getting pal prog signal.
    I rec'd my 963 sa this AM and multi regioned it ok.
    Previous threads refer to latest machines being pal prog out of the box so I haven't done the prog scan hack - The light comes on when you switch to prog scan at the back of the player and the picture appears to sharpen.
    All very well I hear you say
    - but my panny 100 projector reports 525p with both region 1 and region 2 DVD's and not 625p with pal as I expected.
    Have I forgotten something? - I don't want to do the pal prog hack and screw it up.
    How do I know what firmware the player is using?
    Any help from exiting owners very welcome!!
  2. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    there's an option in the video settings for the output, 480p (NTSC prog scan) or unprocessed (pal prog).. choose the second option and it should come through on the projector.
  3. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Tim
    It sounds like your 963 is converting pal to NTSC progressive, check the settings in you player menu it is probably set to convert pal to NTSC, if not you will probably have to do the pal prog hack, and then re-do the Multi-region hack.
  4. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Damb! Martin just beat me :(
  5. Jonny1973
    Jonny1973
    There's a bright blue led on the front panel!!!!
    Make sure you have flicked the switch on the rear of the player.
  6. TimF
    TimF
    Jonny
    Bright blue led was on (it comes on with the switch at the back) but I was not getting true pal prog scan despite this being a brand new machine. (525p not 625p)
    Anyway done the handset hack (And the MR hack again!) and there you go - new menu options and 625p on my projector.
    Just been re-watching some disks - truly superb - this is a great DVD player - picture is awsome and sound excellent.
    IMHO after auditioning the Arcam DV88+ (in my system) the 963 is the better player.
    BTW - the blue led is bit bright in a cinema room - will have to stick some tape on it!
  7. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Just out of interest Jonny, is the blue light on the 963sa similar to the decoding light on the Sony DB940 ??
