D
darren7
Philips 962sa
Hi there guys and Girls.
Just a few q about this super DVD player, I had had the player (Hivizone) for around 3 weeks now and I have just started setting it up and would like a bit of connection advise.
I have the component van dam as advised by all you people, (very nice quality)
I am using the Sony vw11ht and would like to just ask what the setting you guys are using on the DVD player.
I have this plugged into the progressive output on the DVD player. On Sony inputs on the screen it says input A prog 525, I think its 525 anyway around that, I thought that the Pal prog was 625, is this correct or is this something interlaced or something?
Should I put this in the other non-prog socket on the DVD? Or is there no way of getting 625, I have to ask this as there is no progressive pal section in the manual.
How are you all connecting yours up and what settings?
I have to say that this is a top player and if you can get hold of 1 do so
what is all this 625 de-interlaced thing about?
Darren
Darren
