Philips 9528 - checkered pattern on sides
Discussion in 'General TV Discussions Forum' started by kerecsen, Jun 5, 2004.
  1. kerecsen
    kerecsen
    Hi everyone,
    I've noticed that my TV set has a "checkered" look near the left and right edges of the screen. It is not particularly annoying, but with certain colors it can be quite visible. I browsed various retailers and many Philips and Panasonic sets show the same issue, to various degrees (some have only an inch or two of this area, others have the entire screen covered by the pattern).
    Normal area: [​IMG]
    Checkered area: [​IMG]
    Bigger picture (about 1/4 of the entire screen horizontally): click here
    It seems to be some pixel-misregistration, but I couldn't put my finger on the exact problem.
    Is this a normal occurence? Can it be adjusted away by some service menu wizardry?
    Thanks!
    ps: I had a hell of a time taking and rescaling a picture without causing colossal moire patterns :) Not to mention that the demosaic algorithm in digicams gets totally confused when photographing TVs...
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    I've noticed the same thing.
    I've often seen it on Toshiba sets. The pixel structure at the sides of the picture is more noticeable than those across the rest of the screen. It almost looks as if the pixels are slightly elongated, while the pixels across the screen's centre are square.
    It's very unlikely that there's any way to eliminate this, as I think it's down to the actual construction of the tube.
    As you say, it's quite easy to live with, but I've often wondered what causes it.
  3. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,117
    Leicester
    +48
    Yes, it is normal, it's the stretching of the picture width ways, as a result of the 16:9 ratio.
