philips 880
Discussion in 'Blu-ray & DVD Players & Recorders' started by helter, Dec 22, 2002.
  1. helter
    helter
    Nov 22, 2002
    115
    can anyone tell me if you can use cheap dvd+rw in this machine or can you only use philips ones
  2. dr snuggles
    dr snuggles
    hi! i purchased different makes of dvd+rw media in new york recently and they all work fine on my system (985). however each disc did state that the recordable media was usable on both pc and standalone dvd recorders! I believe that you can pick up reasonably priced dvd+r or rws at dabs.com. I got them at reasonable prices in the states! there should be no difference between your 880 and my 985!
    cheers
    dr snuggles
  3. Sarge
    Sarge
    May 30, 2002
    125
    +5
  4. alan8477
    alan8477
    Dec 17, 2001
    590
    Pershore
    +10
    I use Intenso, about as cheap as you can get at £1.50 +R and £2.50 +RW.
