Could somebody please explain just why this is only £399 at RS?
Zog Established Member Sep 4, 2002 #1 Could somebody please explain just why this is only £399 at RS?
Messiah Distinguished Member Sep 4, 2002 #2 Because that is the going price. It is a low spec DVD recorder hence cheaper than most/all others. Got one for my neighbour for £378 delivered from Comet.
F fredl Standard Member Sep 4, 2002 #3 Messiah: Do you by any chance have an idea of whether the 880 can select the PAL format for the tuner? Since my original plan of getting a UK version DMR-E30 of this reason I'm exploring other avenues.
Messiah Distinguished Member Sep 4, 2002 #4 UK models are already set to PAL.. Did not see any option to change it to anything different.
F fredl Standard Member Sep 5, 2002 #5 I dowloaded the manual which mentions a country setting maybe this will change the PAL format between PAL/I and PAL/BG. Thanks!
