andreihanea88
Hello,
So I was very happy this last weekend because I've bought a black friday deal TV - Philips 55OLED854, with nearly 1100 EUR which was a really good deal. I was glad about the Ambilight, HDR10+, good panel reviews, great design. After initial setup and a minimal calibration i immediately started noticing the judder /stutter in all the cinematic scenes, because for the movie mode i've canceled any motion processing. The judder is very very annoying it is always there, I compared side by side with my Samsung KS8000 with no motion on and the judder is more visible on the Philips.....maybe it is the OLED instant response and contrast that make it so obvious.
The second problem is that I've tried all the settings possible to find the perfect spot (like on Samsung KS8000 - 2 for blur 3 for judder in the custom motion settings) of reducing judder without creating soap opera effect or introducing interpolation artefacts....Well at Philips 854 (most probably the same as for 804) I cannot find this sweet spot, while going to Motion Styles > Personal > I found that for Perfect Natural Motion turning it from off to minimum it instantly gives the soap opera effect and many artefacts in motion and increasing it it makes it worse. Perfect Clear Motion seems to do nothing. I am very bodered about this issue and although dolby vision movies look great I cannot stop my mind from seeing all this faults in the image processing.
My question is if there are any settings that I should try or recommendations or if not should I return it put some extra 100 EUR and buy LG 55 OLED B9, is it any better overall and especially in motion processing and judder reduction?
Thank you!
Thank you!
