philips 7504 no 4k native on pc
mcplata
Hello,
I connected my 7504 to the pc using different hdmi cables (high speed) and a nvidia 1080ti.
The problem is that the nvidia panel says is 1080p native, but let me use 4k modes (i suposse are upscaling).
The hardware says is using philips ftv but in drivers it says generic pnp monitor.
I have tried everything (related on tv- hdmi optimal- etc) reinstaling drivers (clean mode) but always says that tv is 1080p native in nvidia panel (but offer me 4k modes too).
using monitor asset manager software says the same:
Monitor
Model name............... Philips FTV
Manufacturer............. Philips
Plug and Play ID......... PHL04C3
Serial number............ n/a
Manufacture date......... 2019, ISO week 19
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 1440 x 810 mm (65,0 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA/CTA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,640 - Ry 0,330
Green chromaticity....... Gx 0,290 - Gy 0,600
Blue chromaticity........ Bx 0,150 - By 0,060
White point (default).... Wx 0,289 - Wy 0,299
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-70kHz
Vertical scan range...... 48-62Hz
Video bandwidth.......... 600MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1920x1080p at 50Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1680 x 1050p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1400 x 1050p at 60Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
EIA/CEA/CTA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
CE video identifiers (VICs) - timing/formats supported
Supported
Supported
Supported
Supported
Supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
1920 x 1080p at 100Hz - HDTV (16:9, 1:1)
1920 x 1080p at 120Hz - HDTV (16:9, 1:1)
1280 x 720p at 100Hz - HDTV (16:9, 1:1)
1280 x 720p at 120Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
DTS 6-channel, 1536k max. bit rate at 32/44/48 kHz
DD+ 8-channel, 16-bit at 44/48 kHz
DTS-HD 6-channel, 16-bit at 32/44/48/88/96 kHz
DVD-A 8-channel, 16/20 bit depths at 48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 3.0.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 300MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. Yes
EDID screen size......... Correct aspect ratio, but approximate size
3D formats supported..... Not supported
Data payload............. 030C003000383C200860010203
IEEE registration number. 0xC45DD8
CEC physical address..... 0.1.7.8
Supports AI (ACP, ISRC).. Yes
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Maximum TMDS clock....... 15MHz
HDMI video capabilities.. No
Data payload............. D85DC40178800302
CE video capability data
CE scan behavior......... Always overscanned
IT scan behavior......... Always underscanned
PT scan behavior......... Not supported
RGB quantization range... Selectable (via AVI YQ)
YCC quantization range... Not supported
YCbCr 4:2:0 capability map data
Data payload............. 0F03
CE colorimetry data
xvYCC601 support......... No
xvYCC709 support......... No
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
BT2020CYCC support....... No
BT2020YCC support........ Yes
BT2020RGB support........ Yes
Metadata profile flags... 0x00
HDR static metadata
SDR luminance............ Yes
HDR luminance............ No
SMPTE ST2084............. Yes
Hybrid log............... Yes
Data payload............. 060D01
CE vendor-specific video data
Data payload............. 0146D000444743983907A3
Data payload............. 018B849001
CEA/CTA vendor-specific audio data
Data payload............. 1146D0007000
Report information
Date generated........... 08/12/2019
Software revision........ 2.91.0.1043
Data source.............. Real-time 0x0081
Operating system......... 10.0.18363.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,41,0C,C3,04,01,01,01,01,13,1D,01,03,80,90,51,78,0A,E6,92,A3,54,4A,99,26,
0F,4A,4C,21,08,00,B3,00,95,00,A9,40,90,40,81,00,81,80,81,40,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,A0,2A,53,00,00,1E,02,3A,80,D0,72,38,2D,40,10,2C,45,80,A0,2A,53,00,00,1E,00,00,00,FC,00,50,
68,69,6C,69,70,73,20,46,54,56,0A,20,00,00,00,FD,00,30,3E,0F,46,3C,00,0A,20,20,20,20,20,20,01,A8,
02,03,75,F1,5B,61,60,5D,5F,5E,10,1F,20,22,21,05,14,04,13,12,03,11,02,16,07,15,06,01,40,3F,29,2F,
32,09,1F,07,15,07,50,3D,07,C0,57,06,01,5D,1F,01,67,04,03,83,01,00,00,6D,03,0C,00,30,00,38,3C,20,
08,60,01,02,03,68,D8,5D,C4,01,78,80,03,02,E2,00,49,E2,0F,03,E3,05,C0,00,E3,06,0D,01,EB,01,46,D0,
00,44,47,43,98,39,07,A3,E5,01,8B,84,90,01,E6,11,46,D0,00,70,00,00,00,00,00,00,00,00,00,00,00,AE
What can I do? some other philips user, can tell me if once connected to the pc, it offer 4k as native mode? also the tv apperars as generic pnp - philips ftv?
helps please!!
EndlessWaves
You've got it plugged directly into the HDMI port on the video card? You're not using any adaptor and haven't connected it to the motherboard HDMI port?
mcplata
Yes, directly on hdmi of the 1080ti card. I have another 4k tv (lg) and it works as native 4k resolution, but changing to this new philips tv, says its 1080p native but allow 4k resolutions,
Very strange
Sensenmann12345
Did you ever manage to get this resolved? I'm having the same problem with my tv. My tv is pus8105/12.
Sorry for being late to the party.
I could fix it with using CRU:
Go down to "Extension Blocks" and click on "add".
Next choose type "DisplayID 1.3" from the Dropdown.
Now again click "add" --> "Detailled Resolutions"
Here you choose 3840x2160 60Hz with Timing "Automatic (HDTV)". Click the "Preferred" Checkbox on the lower right Corner.
Now you either reboot your Computer or use "restart.exe" (for 32bit Windows) or restart64.exe from the CRU Folder.
Voila!
afwz57
@Sensenmann12345 thank you!
The issue still occurs in December 2022.
I tried both your CRU workaround and this one linked here:
As a recap from the previous thread here's what was tried:
  • using several AV receivers
  • directly connecting the PC to my 55POS9002
  • using HDMI 2.0 & 2.1 cables
  • using several of the latest graphics cards
  • using other 4K native TVs
and still the issue only occurs on my Philips set.
Philips customer service did not help either. What a pity!
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
