Question Philips 73 vs 82
pauljb1
Hi. I see there is the 50 inch Philips 7334 for a bargain at 449 or the 8204 for 499.
however can you tell me what is the difference between these two TVs? Is the 8204 much better?
also would you recommend any of these two TVs. Local dimming appears to be included so should give good contrast and blacks.
any thoughts to help me decide? Or should I stick with a 43inch Samsung 7400 for a similar price?
thanks
Anvoyager1
Hi Paul,
I was in the same position deciding which one to go for. After some research I decided to go for the 8204 @ £499 in Curry`s.
Anvoyager1
Anvoyager1
Any thoughts on the TV? and what made you go for the 8204 in the end?
Hi Paul,
I was looking for a review online but there was none on the 8204 there was a few on 7334 so I finally went to Phillips website and did a comparison the 8204 is has a slightly better spec.
Anvoyager1
Hi Paul,
The tv has not been delivered yet, because is a Christmas present I didn't want receive it right now because of the 30 days return policy so I think is getting delivered on the 16th of December.
Racy Jace
What size screen was that? I was thinking of a 50" 7334 Philips as a cheap 2nd TV.
Hi Paul,
original77
I've done so much tv research this last week my head is spinning, but i've settled on definitely wanting Ambilight, and swaying towards VA, after seeing some terrible reviews of IPS on Amazon, particularly the glow and washout, and I do tend to watch tv in a dark room.
Two contenders are 50pus8204 + 55pus8204
50 is definitely VA
55 i'll happily pay the £100 more for at £599, but i've a sneaking suspicion its IPA, but can't confirm :(
Do these 8 series have the better sound too VS 7 series?
I have read they should have more bugs ironed out which may have effected 7 and 6 series.
original77
Heres my short list and thought process so far
*8204 about to buy, ambilight, VA panel + 1900 PPI
*Any attempt to move up to 55" thwarted with IPS panels
*Consider saving £100 on other VA 50" but get lower PPI and 6 or 7 series with potential poor software/slower processors?
*Keep ending up back with the 8204!
8204 £499
7334 £449
6814 £399
6754 £399
Anvoyager1
I think you should stick with the 8204, I just saw a deal at Cosco from hot deal 70pus7304 for £790 if you are Cosco member that is tempting
Neoakira
Hi - has anyone got a link to a review for the 8204 series, I can't find anything online... Trying to work out where the 8204 fits into the Philips range and is it a 2019 TV? Thanks
spmorley30
It's a 2020 tv and for the price I cannot fault it, had it about 3 weeks now.
Neoakira
Thanks spmorely, it's strange I can't find any details on this TV anywhere on the web!? Currys are doing the 50" at £399 which looks very tempting. Although I wary of purchasing from them...
spmorley30
I was the same but took a punt on it, dolby vision looks good, gaming in it is also very good, I would say input lag around 25-30ms which is more than acceptable. 4k hdr content on YouTube is breathtaking. For less than 400 it really is a bargain
Neoakira
Cheers, appreciate the prompt response - think I will go for it :)
Stitty10
I am really lost on what to choose. I was going to get the 6754 which is £50 cheaper than the 8204. Is the 8204 worth the extra price?
AVtest
100% 8204 is better choice and worth extra. 1200PPi vs 1900PPI I guess should be very noticeable in picture quality.
Stitty10
Thanks, I managed to find a comparison website, there didnt seem too much different other than the ppi and operation system (I think 8204 is android and 6754 is saphi.
A friend has the 6754 and we have decided to go with that
Similar threads
Trending threads
Latest News
Denon introduces 8K ready AV Receivers as industry's first
  • By Andy Bassett
  • Published
CES 2021 to go ahead 'in person'
  • By Andy Bassett
  • Published
Philips 800 Series OLED TVs come to UK in July
  • By Andy Bassett
  • Published
AVForums Podcast: 31st May 2020
  • By Phil Hinton
  • Published
MQA expands global partnerships for high end experience
  • By Andy Bassett
  • Published
