Philips 723 slimline & DTS
Discussion in 'Blu-ray & DVD Players & Recorders' started by Doorman80, Jul 17, 2002.
  1. Doorman80
    Doorman80
    Jul 11, 2002
    84
    I've just bought a Philips 723 slimline DVD player. Now I've just been on the philips website & I can't see a DTS logo on the front of the dvd, it only has dolby digital. The dvd has an builtin DD decoder & optical/coax out, So i just wanted to know if DTS will work when I connect the dvd to my Marantz SR4200.
    Thanks in advance
  2. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    I haven't checked the spec of your player but.
    It should output the DTS signal for your Marantz sr4200 to decode via the coax or optical out. Just select the DTS soundtrack from the DVD disk audio options. Set you 4200 to auto or select DTS manualy and away you go.
  3. Doorman80
    Doorman80
    Jul 11, 2002
    84
    Great thanks
    Its just strange they left the logo off the front.
  4. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    I would not worry too much.:)
  5. JCW
    JCW
    I heard the dts logo cost 2 bucks...as long as it works, who cares?
