Philips 65PUS8536 65
killie77
Not sure which part of the Philips forum to put this. But I hope this is the place.
Bought the above TV had it delivered yesterday, have it set up. But I'm looking for any calibration settings if their are any around ?.
I have Polk Soundbar, that I might use that with the TV. The Polk has one HDMI it's the PolK mini.
Do I be checked the TV and I think I'm right thet HDMI 3 has Arc. I've selected HDMI as the sound output but nothing is coming through the Polk.
Checked connection seems ok.
Anyone have any ideas ?
Ian
HAM5ter84
Probably worth checking out the 85xx, thread on here for calibration. Sound bar wise should be arc out from the sound bar to arc in on the TV. All ports support arc. Not sure what standards the soundbar supports, but Dolby Atmos your want the e arc out from the soundbar to the earc , which is hdmi 3 from memory.
On the soundbar you may need to set up hdmi audio out on it and hdmi CEC had to do this on my Yamaha ysp1600. Also on the Audio out make your you select hdmi sound not TV speaker.
If you want to have the internal apps pass back and going to have your devices connected to the TV fully utilising arc then you may need to set to TV rather than hdmi output had to do this on my soundbar.
Also if it supports Dolby digital plus your want to select digital out on sound then advanced to multi channel bitrate otherwise multichannel will pass out multi channel audio.
Hope that helps.
killie77
Thanks for the reply.
The Soundbar I have is the Polk Magnifi Mini.
I've read that these have problems with HDMI connection dropping out. I'm hoping to update the firmware,
Ian
HAM5ter84
Ian
Hi, from looking at a manual online. It should be a simple option of the hdmi arc on your soundbar to any of the hdmi arc ports on the TV. Then set the audio out in whatever it calls itself mine is hdmi audio system. Then on the soundbar check the bottom white light is lit. This shows the hdmi arc connection is working. Then if there is a Dolby source it should light up on that indicator. Start with multi channel on digital out then you should be able to test with one of the internal apps. Looks pretty simple setup.
Having checked out expert reviews of the soundbar it does decode Dolby 5.1, so multi channel will be fine. If you select multi channel bit stream then I dont believe your get any sound passed or chopping.
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
