Philips 55PUS6703 - Motion problem
Darbo
Just wondering if anyone else on the newer firmware is having problems with All4? Had this months ago where you try to launch All4 via the shortcut, the logo appears for a second, then it just goes back to the TV/HDMI or whatever you were watching before. Can't get it to work via the EPG either.
I had that from day one, actually started working properly after the update so the opposite of what you're having.
The workaround was going to one of the 4 channels and using that to get to all4, it worked fine from there.
Edit, just noticed that doesn't work either... Sorry bud.
Darbo
Anybody had any experience with customer services? Two lines running the length of my tv have appeared today, definite hardware fault, I've only had the tv a year so it'll still be in warranty, just wondered if I'm in for a fight or not...
SmAShY
Has Ambilight+Hue stopped working for anyone since the firmware update that fixed the motion?
RustyMG
Funnily enough, and I dont know how I didnt notice, but mine was off too, despite being "on" in the settings. Just went into the settings, moved off then back on to "follow video" and back it came.
SmAShY
I had to reset configuration but all done now.
Similar threads
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
