Quantcast
Philips 55OLED934 - dumb, stupid, idiot, noob question!
handsy
As this TV comes with it's own soundbar can I assume that I would simply connect that optically to the TV and then connect all my sources (bluray, set top box, Firestick) directly in to the TV HDMI ports?
I'm guessing ARC is available for all TV HDMI connections?
coachdriver
You connect the sources to the TV.
There is an included cable you plug In from the TV to the soundbar as you put the stand together.
ARC is available on all 4 HDMI ports if using an external sound bar.
handsy
Ah OK, so the supplied soundbar does not use ARC, it's built-in? All TV HDMI inputs would automatically send audio to the supplied soundbar?
coachdriver
That’s right. All 4 HDMI slots are available for your use and the sound bar is from a different connection.
Have a look at the manual online.
I have 3 in use by a Freeview recorder, Blu-ray and AppleTV. Very simple and sound with a subwoofer in use is very good for a TV. Not a match for a true surround system but very good for a minimalist looking setup.
