Quantcast
Philips 55OLED903 Sound Issue
MrStavros88
Has anyone had any issues with sound on the Philips 55oled903 tv??. It’s intermittent. When watching all sources sky q , Netflix etc the sound it very tinny. Thanks in advance
JayCee
Was it okay to begin with and now has become “tinny”?
Have you tried adjusting the audio settings?
Mszune
I'm having the same issue when using a shield TV pro 2019 sound is clicking/cherping when watching Amazon prime YouTube or Netflix did you resolve the issue? The sound on my 55oled903 was also good when we first had the TV but has worsened over the last two weeks.
Joop21
Registered myself specifically for this issue. I have the same issue, 55OLED903 have it for +/- 7 months now and recently the sound is having issues as described by original poster. Netflix, amazon prime etc. BUT here in The Netherlands I can watch Netflix also using their top media box , when watching Netflix on the media box there are no sound issues at all. Watching regular tv also no issues. So I think it has to do with the android software somehow and it’s not hardware related.
If someone has an update , let us know !
rgds,
Joop
Mszune
Hi all,
A firmware update was released on the 12th of December to fix a number of audio related issues, including a faster EPG. (no sound now when you search the TV guide 🙄) however after the update you then have to complete a factory reset that resolved any audio related issues. Initially I thought it was my Nvidia shield 2019 pro, but upto now it seems as though it's the TV. Hopefully the above information will assist you to rectify your issue.. 👍🏼
Mszune
That's the advice I had off Philips tech support after a firmware update, glad it worked for you as it did me 👍🏼
Joop21
Didn’t last long , that annoying sound is back again. Does anyone know where to report this to the manufacturer?
Similar threads
