The build quality is a bit on the plastic side but it's a reasonably well made TV. Ambilight can be a gimmick if you use it in the mode where the colours and brightness change to match the images on the screen but the ISF mode just produces a constant neutral bias light behind the TV, which makes viewing in the evening more comfortable and improves the perceived blacks.
Philips mainly use VA panels. Yes we'll be reviewing the 65" 7601 with FALD very soon and then we'll take a look at the new OLED TV in late October or early November.i was asking about the philips models in a thread.
will you be getting your hands on the higher end 65" models,are the philips ips or va
Great! It would be awesome if you could check that. thanks.We'll be reviewing the 7601 soon, so I'll be able to answer that question directly then.
Interesting picture - do you know what its source is?Hello,
What is the difference between 55PUS6581 - 55PUS6501 - 55PUS6561 - 55PUS6551 ? All of them 400 Nit - HDR Plus - Direct LED - IPS - 100 Hz (https://store.donanimhaber.com/f5/f1/72/f5f172b0d1fd17891df825139b0affef.png)
There is a small differences like ambilight side, voice search.
Hi thanks for the review, do you have any idea how the Philips 55PUS6401 available at Argos differs from this set?
