slimlife
Hello,
I have a Philips 43PUS8506 TV (supposedly MVA matrix).
The TV set to the factory settings, unfortunately, leaves a lot to be desired in terms of the image. It is especially visible in dark scenes where the picture looks tragic. Instead of a smooth color transition, there are huge black spots, etc.
I had the previous model, i.e. 8535 and 7304, and in them the factory image was much better, especially the dark scenes. On the previous ones, it was also much easier and better to calibrate the image.
As for the 8506, I tried various settings from the Internet (internet forums, youtube etc.) and after using them the image is much better, while the improvement of dark scenes still leaves much to be desired.
Is there anyone willing and able to help with some better calibration settings?
I will be very grateful.
regards
regards
