Philips 42PFL5522 Vs Philips 42PFP5522
Discussion in 'Philips TVs Forum' started by michaelscullion, Sep 15, 2007.
Tags:
  1. michaelscullion
    michaelscullion
    Ok...
    so they are both practically the same TV in terms of spec...both Philips, both 42"...etc etc
    which one would you say is better
    • The LCD is higher resolution 1366 x 768 as opposed to the Plasma's 1024 x 768
    • The Plasma has a slightly higher refresh rate of 3ms instead of 5ms
    What would be better for say, 70% Freeview, 20% Xbox 360, 10% DVDs...
  2. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    As the PFP is plasma then it has better SD performance than the lcd.Simply be careful for burn in
