Philips 42PF9965
Discussion in 'Philips TVs Forum' started by Arshad, Oct 21, 2003.
  1. Arshad
    Arshad
    Does anyone know if the DVI input on 42PF9965 is HDCP compliant?
    I heard that it cannot accept PAL progressive, does it accept NTSC progressive?
    Is there a way to make it accept the PAL or NTSC progressive?
    I was told by the sales person that if i want to use the progressive scan function on my dvd player i need to connect the dvd player directly to the panel instead of connectiong it through the E box, strange?
    Also the DVI input is in the panel not in the E box?
    Also does the component inputs on these plasma means that they are inlerlaced, progressive or broadband component, i'm a bit confuse here?
    Also in Hong Kong now the new philps model number is 42FD9954 + FTR9965 E box, not 42PF9965, isn't the 42FD9954 an old model but with the new E box?
