Philips 42PF9946 Question
Discussion in 'Philips TVs Forum' started by phetttt, Apr 9, 2005.
  1. phetttt
    My brother has recieved his shiny new Philips 42PF9946 and has put up a false wall to mount the plasma on. The bracket used is fixed onto 6'x2'x7" wood using 4 heavy 2.5 inch screws. He is concerned that this will not take the weight (42kg) although he did hang the panel overnight and it did not fall off!!
    I couldn't believe how heavy plasmas are!!
    Any ideas?? I don't know if this is the correct thread but any help would be appreciated.
