Philips 42PF9946 Plasma
Discussion in 'Plasma TVs' started by Pooon, Feb 1, 2005.
  1. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
    [​IMG] question. Does this Plasma TV support Progressive Scan? I ask as it the screen does not appear to have any Component Inputs, which i thought were required for any device to support Prog-Scan, or is this just applicable to CRT screens?.
  2. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    856
    Lancing, West Sussex
    +60
    I would guess it does not. I have a Philips 37PF9965 (which does have component inputs), and even then, it is not able to accept a progressive signal via component. Having said that, the interlaced component signal with Pixel Plus processing is absolutely awesome. I think you may be able to get a progressive signal into the Phillips via VGA (RGB or Component colourspace).
  3. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
    So really thats a no then.
  4. lemke
    lemke
    I have the 42pf9966, and this Plasma also hasn't Component. But besides the PP2, it has to more digital option, Movie Theatre and Progressive Scan.
    This Plasma controls it internaly and make the incoming signal progressive.
    Works fine.
    Lem
  5. Maxi_TK96
    Maxi_TK96
    Mar 31, 2004
    117
    16
    Helsinki
    My 9966 also lacks component but does have DVI which produces very a very detailed pic. Also it seems that DNM (digital natural motion) behaves differently when using DVI meaning the pic is moving more smoothly if you use analog sources. Because of this the analog side suffers a bit from motion dither unlike the DVI pic which is free from this. I mainly use DVI for movies and the analog side for console games (benefit from smoothy loving pic by DNM) and digital TV.
  6. hansje
    hansje
    Jan 19, 2005
    hello,
    I have an interface cable from component to VGA connector and this can be connected to te set via VGA-DVI connector.
    In this way it is possible to use the component input. :clap:
    hans
  7. Maxi_TK96
    Maxi_TK96
    Mar 31, 2004
    117
    16
    Helsinki
    If you have 9966 I really suggest that you feed 1080i to this telly. Since the ALis-panel is interlaced (1024x1024i) that particular 1080i suits it best. If you use progressive the effective vertical resolution will be halfed.
