PHILIPS 42PF9946 & dvd player. (what to do ?)
Discussion in 'Philips TVs Forum' started by chaddy, Aug 31, 2005.
  1. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    Hi peeps, after having a pv500 in the house for quite a bit now, my girlfriend has aquired a PHILIPS 42PF9946 for the bedroom for £800 :devil:
    Yes before you say it i know its not the best plasma out there, but for that price can't argue.
    now after a bit of research i've found that it doesn't have component inputs, yet the phillips webpage says it has prog scan..................HOW ?
    so after thinking, what would be the best way !
    Scart 2 ? (non RGB as sky will take up scart 1)
    Component to VGA ?
    cheers all.
  2. superpixel
    superpixel
    2 easy options:
    1. Plug the DVD player into the VCR Scart of the Sky Box, this will passthrough RGB when switched into standby.
    2. Use an S-video & Audio to Scart cable, to connect the DVD to the other scart which accepts s-video.
    What d'you think of the PQ?
  3. chaddy
    chaddy
    Jul 7, 2005
    1,620
    48
    Manchester
    +66
    not got it yet, just awaiting delivery.
