Philips 42PF9945 issues with the progressive component input
Discussion in 'Plasma TVs' started by fredde, May 28, 2004.
  1. fredde
    fredde
    Hi all
    I have a question regarding progressive scan. My Philips 42PF9945 has a progressive scan component input. If I use this with a DVD player with progressive scan will this improve ghosting on the plasma?
    Today I use "old" Philips DVD 957 and I am not pleased with the ghosting issue when skin moves fast horisontaly on the screen. I have tried the Pioneer 5100hs DVDRecorder and it improved picture quality a lot even if it don't have progressive scan (or component out).
    Anybody got some experience around this subject? :lease:
    Specs for 42PF9945 panel:
    New 42PF9945
  2. fredde
    fredde
    Ok, I will answer it myself :)
    Yes, gosting will almost dissapear if progressiv scan is activated on Philips DVP630. Only negative is that Digital Natural Motion seems to be turned off.
  3. xfire
    xfire
    I have the 42PF9945 too.
    I used a Philips DVD737 (connected via SCART - no Progressive Scan)
    Now I'm planning to buy a DVD630 (connected via component - with Progressiva Scan).
    Do you think that I will improve picture quality? even with DIVX material?
    Thanks.
