square-eyes
Established Member
I've just got my Philips LCD 42PF7621D. As it is a bit on the huge side, I thought I would wall mount it. I think it is important to connect every cable you might ever use before lifting it into place as popping another cable in the back will become impossible.
I want to connect my PC to the screen and, as I only have VGA output on the PC it has to be connected to the TVs component (5 X phono) connectors. Does anyone know where I can get a VGA male to 5 phono cable? I can find them for about $6 in the US but nobody seems to have them in the UK. It is a pity Philips didn't put a 15 pin VGA socket on the TV.
