Philips 42PF7
Discussion in 'Philips TVs Forum' started by 65jona, Jan 25, 2008.
  1. 65jona
    65jona
    I have a philips 42 inch plasma which I have had for two years and is working great. I have just purchased a Harmen Kardon Amp with HDMI input output on the back. My TV is connected via HD DVi with sound through the amp. I also have a PS3 connected through HDMI. My problem is when using DVD or PS3 for play back I get horizontal lines of green spots during dark shots. I have taken the AV Receiver back to the store and they have swapped it but that didnt work. I have swapped my leads and that doesnt work. can ayone please shed any light on this as while the sound is fantastic its reall spoiling the picture
  2. UKseless1
    UKseless1
    Mar 9, 2005
    842
    28
    +36
    Tried plugging directly into the the TV as part of your problem determination?
  3. 65jona
    65jona
    Thanks. I have just tried this plus commected the sound by coaxial and it works perfect. Must be an amp issue so I'll go to Harmen Direct.
  4. 65jona
    65jona
    Tried top quality leads and shop tested amp, all working well. Shop says may need a seperate HDMI spliter which has a booster on it. Thibks it may be TV??
