Philips 42PF 5421 LCD Widescreen Problem!!!!
M
man1
Hi got this lcd tv (42PF5421D) 3 months back in dublin,
am kinda happy with it so far but it isnt great when you watch football as it gets blurry and is hard to make out which player is which sometimes, i have seen football on it somewhere else in HD and was impressed by the difference so will have to wait i suppose for HD tv to become cheaper,
a HDTV box over here is €450 (£320) at the moment and an extra €180 per year subscription with SKY!!!
However my one real complaint and I have only just started to notice it, is that the widescreen function is either not working or i just dont know how to work it myself.
I have noticed it with Irish tv especially rte and tv3 (although it is with some sky channels as well), the problem is that you cant see the full width of the programme on screen and the stations logo is halfway off the screen. The top and bottom of the screen seems to be ok , it is just the sides, seems to be stretched too much.
It is like watching it on a standard non-widescreened tv. I have tried to change the settings, superzoom, widescreen etc but cant figure it out.
Should it be like this???
Help please!
Andy98765
How is the picture delivered to your TV. Sat/Cable/Aerial etc
Do you have a set top box for the transmissions, if so what is it.
P
Primitive Nick
Sounds like your set top box is set to output 4:3 rather than 16:9 and therefore the STB is cutting off the sides of the widescreen channels. Doesn't sound like a TV problem.
P
Primitive Nick
Press the services button on your Sky remote and then select picture settings and check what the output format is set to.
M
man1
DOH!
Didnt think to try that.
Will do when I get home later and let you know.
I knew it would be something simple.
Andy98765
Also whilst you are in the box it should be set to RGB not PAL (use a good Scart cable to a RGB enabled Scart socket on TV) and as stated switch to 16:9 not 4:3
Similar threads
