Philips 37PF9986 Wall Bracket
Discussion in 'Home Cinema Buying & Building' started by turnje, Mar 8, 2005.
  1. turnje
    turnje
    Feb 14, 2005
    Hi All
    I am looking to buy a Philips 37PF9986, but am interested to know what the wall bracket is like. I have a stud wall and I am trying to gauge how much work is going to be involved mounting it on the wall.
    Does anyone have a picture and/or dimension of the bracket.
  2. ap69
    ap69
    Jan 28, 2005
    430
    +15
    I used to own this screen. Don't have the exact dimensions but the supplied wall bracket was approx. 18" wide by 9" high in size.
    It's a very simple bracket, with 6 holes each on the top and bottom horizontal edges.
    I would imagine it's gonna be trickey to attach to a stud wall as the timbers will be too far apart. I attached to a brick wall no problems, but you'll probably have to insert additional tiber studs to take the screws of the bracket.
