Philips 37PF5520D - wall mounting bracket enquiry
Discussion in 'Home Cinema Buying & Building' started by U0011726, Sep 5, 2005.
  1. U0011726
    U0011726
    I recently bought a Philips 37PF5520D LCD TV and was very suprised to discover that there wasn't a wall mounting bracket in the box !
    Can anyone suggest where I can get hold of a bracket ???
  2. dannyvic
    dannyvic
    hi have the same tv, asked philips for help with no joy bought a plasma mount of eBay with the promise that it would fit my tv of course when arrived did not fit!
    my son found that the vogels mount will fit efw2004 £98 from costco. Hope this helps
    Danny.
  3. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Is the TV VESA compatible? ie look on the back for some holes in either a 100x75mm , 100x100mm , 100x200mm , 200x200mm formation.
    mine is 200x200mm so I have 8 holes in a square.
    There are loads of different brackets available if thats the case.
    If not then the one you bought might be useable with a an adaptor bracket, lots of online bracket sellers sell these.
  4. HCK
    HCK
    Oct 21, 2002
    740
    46
    West Yorkshire
    +116
    I am considering buying this.....HCC recently slated it...is it as bad as they say ? I use Telewest Cable TV will the picture quality be good through scart ? Does it really suffer through aanalogue sources ?
    Any help is appreciated ?
  5. dannyvic
    dannyvic
    i use scart from sky+ picture is very good
    it is a vesa mount but the size is 800 / 400 the screen size is only 37" way they had to go so big with the mount size i don't no?
    danny.
