Philips 37pf5520d And 37pf9830
Discussion in 'Philips TVs Forum' started by philbam, Oct 21, 2005.
Tags:
  1. philbam
    philbam
    Dec 22, 2004
    2,250
    Pontypool
    +195
    Could someone let me know what the main differences are between these two 37 inch LCD's from Philips.
    On checking on the NET the price difference is enormous - £1299.99 for the 5520D and £2400 for the 9830.
    They both appear to be HD ready so what benefit has the dearer one have over the other??
    Any advice or information would be most welcome.
    Thanks!!
  2. machinehead
    machinehead
    Sep 5, 2004
    468
    Greenock
    +15
    philbam if you do a search throughout this thread and forum you will find the answers that you are looking for.ambilight,pixel plus 2 are just for starters.
    regards machinehead
  3. Mikeyg47
    Mikeyg47
    Sep 29, 2005
    132
    Hi mate,
    Just to let you know a few of the differences.....
    the 9830 has...
    A motorised stand, ambilight feature, the main difference is the panel resolution which is 1920 x 1080 (whereas the other only has 1366 x 768)
    I hope this helps you out but as above, if you do a search you will find loads of details.
    Mike
