philips 36pw9618
Discussion in 'General TV Discussions Forum' started by theo, Sep 8, 2004.
  1. theo
    theo
    is it possible to connect a progressive scan dvd player
    to 36pw9618?
  2. GlennP
    GlennP
    Yes but the TV won't accept progressive input from what I remember reading about the TV spec but I stand to be corrected - check the spec or speak to Philips - if it doesn't say "Progressive scan" then it won't.
  3. torkelom
    torkelom
    Jul 15, 2004
    39
    Norway
    I don't think Philips has a CRT TV which accepts the progressive input.
  4. Phil55
    Phil55
    The TV has Progressive scan built in.
  5. GlennP
    GlennP
    Are you sure???? Where does it say that in the spec?
    Don't you need to have component inputs on the TV? - the 9618 doesn't have component, only scart!
  6. Phil55
    Phil55
    Yes I'm sure and if you have one like me then you will have the manual on page 11 of which under digital options you will see that whenever it is fed an NTSC signal you have the option to select Movie plus, Pixel plus or Progressive Scan.
    When fed a PAL signal the Progressive Scan option turns to Digital Scan whicch I have read is the same thing really.
  7. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    Seems to be a little confusion.
    "Is it possible to connect a progressive scan dvd player?" I think Theo meant to add "outputing a progressive signal?". I believe only certain Loewe TVs accept progressive input via Scart so unless it has a separate component input, the answer is - no it is not possible. Interlaced RGB is your best bet. That said, the TV can take interlaced frames and convert them into pseudo-progressive. Depending on how well the TV does it, the "Progressive scan" setting will look more like a true progressive output from the DVD player.
