Philips 36PW9618 picture freeze with SKY RGB enabled
Discussion in 'General TV Discussions Forum' started by Lunny, Sep 27, 2004.
  1. Lunny
    Newbie on the forum and I'm hoping you can help.
    I have just bought a Philips 36PW9618 TV and I have connected a Toshiba RD-XS32 DVD Recorder and a SKY Digibox (PanasonicTU-DSB30) to AV1 and AV2 of the TV.
    The problem only appeared when I changed the setting to RGB on the SKY box. The picture now freezes altogether or freezes then restarts with a high pitched noise.
    The TV is detecting an RGB signal as this is stated on the TV when the channel is selected. At first I thought it might be the cheap scart cables I was using so I purchsed some IXOS XFT02 cables but the problem still exists.
    Currently I have switched the SKY setting back to PAL as the RGB setting is unwatchable. In PAL mode everything is working fine.
    Any suggestions anyone as this is spoiling my enjoyment of what is otherwise a very good TV.
