Philips 36pw9607 Pixel Plus TV dimensions
Discussion in 'General TV Discussions Forum' started by beavis, May 16, 2002.
  1. beavis
    beavis
    If anyone has the above model, do you know what the size dimensions are for the tv?
    Just waiting for JL to get the PP sets in stock and I was thinking about going up to the 36" model instead!
    Had a look online but couldn't find anything for this model, dimensions for the 32" are
    height : 549mm
    width : 847mm
    depth : 539mm
    Cheers all!
    B.
  2. Ludae
    Ludae
    I would imagine the 36PW9525 is virtually the same size.
    WHD
    927, 638, 570 mm
    75Kg
  3. beavis
    beavis
    oops, just noticed it's detailed on the Empire Direct site.
    If anyone is interested, the 36" has the following dimensions:
    Height 608mm
    Width 941 mm
    Depth 576mm
    Gonna get my tape measure out tonight to see if it will fit! Then I'll just need to hope JL gets stock in very soon!
    Cheers all
    B
