Philips 36PW9525 - what stand
Discussion in 'General TV Discussions Forum' started by bbanduser, Jan 26, 2004.
  1. bbanduser
    bbanduser
    Nov 22, 2002
    1,893
    38
    Watford
    +3
    Hi guys,
    I have bought a Philips 36PW9525 from these forums,and will get it possibly next weekend.Now the TV won't come with a stand,and my existing stand is a bog standard Argos corner unit Link here
    Any ideas if this will be enough to carry the weight of this TV? Or will it simply collapse under the weight?
  2. ELV
    ELV
    Jun 5, 2001
    690
    Up in the proper north
    +11
    There are a few stand out there, i think the tv weighs around 75-80kgs, I also looked for a separate stand when i bought mine but they were so expensive. I got the Philips one in the end and it looks great, you can try to get hold of one although they may have stopped making them due to damage on the front lip,Ive got B&W VM1's so placing the speaker was 'nt a problem (on the top of the tv)but if you're speaker is bigger it might not be suitable.
    P.s the glass shelves on most stands i looked at were rated for 100kg or thereabouts so they will be strong enough but some were just big enough and the tv would have looked a bit big for them.
    Ta very much
  3. Kula
    Kula
    Nov 8, 2003
    38
    Glasgow
