Philips 36PW9525 - Pixellation problems with cable box
Discussion in 'General TV Discussions Forum' started by warrej, Jan 14, 2004.
  1. warrej
    warrej
    Dec 28, 2003
    300
    +12
    I've had a Philips 36PW9525 TV for a couple of years now, and overall I have been hugely impressed with it. The terrestrial picture is very good, and PQ when playing DVDs is superb. However, I have real quality problems when watching channels on my cable box. This problem is especially bad for channels like Sky Sports, which suffer from lots of pixellation problems when watching sports, like footy.
    I think this is due to a combination of factors, probably a poor feed from Sky and the TV's 100hz scanning mode.
    However, does anyone have any hints/tips about how I can improve the picture quality with this particualr set?
  2. ELV
    ELV
    Jun 5, 2001
    690
    Up in the proper north
    +11
    Make sure all picture enhancement modes are turned off. I also have the same tv with excellent picture quality on Sky. Don't know much about cable but could it be a poor signal, or split signal or perhaps line degredation?Is the picture rgb? Make sure the sharpness is turned to about 10% also. It sounds more like a poor feed or receiver problem if you have one with cable? Tried another tv?
    Sorry i can't be of more help but my point is that mines excellent with all feeds except my ariel which has very poor reception anyway.
    P.s make sure the digital picture mode is on 100hz
    Don't those dvds look great though, shame the whole thing seems to shrink the longer you have it, 43" next.
    Cheeers!
  3. warrej
    warrej
    Dec 28, 2003
    300
    +12
    Thanks ELV, I'll take your suggestions on board and have a play this weekend.
    I'm using the second TV RGB Scart socket for the cable box, and am pretty sure the cable box output is RGB.
    If none of this works, I'll have a word with Telewest!
