Philips 36PW9525 Engineer Setup
Discussion in 'General TV Discussions Forum' started by jezzpalmer, Feb 8, 2002.
  1. jezzpalmer
    jezzpalmer
    Jan 27, 2002
    22
    Hi all,
    Does anyone know how to get in to the engineer setup menus for the Philips 36PW9525?
    Also does anyone know of a way to get the TV to default to Widescreen when switched on instead of whatever it does default to?
    Many thanks,
    Jezz.
  2. Taz
    Taz
    On my 32" Philips I went to setup, and changed auto format to NO
    this leaves the picture in 16:9 format.
    Taz.:cool:
  3. jezzpalmer
    jezzpalmer
    Jan 27, 2002
    22
    Cheers Taz,
    Is that in the std customer setup?
    I have looked in the the customer one, will try again.
    Cheers,
    Jezz.
  4. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    I too have this set and would be very interested knowing how to enter the engineers setup. So that I can modify cropping options. At the moment widescreen overstretcheds and cuts off about 20mm each side.
  5. jezzpalmer
    jezzpalmer
    Jan 27, 2002
    22
  6. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Thnnks Jezz,
    Unfortunatley it doesn't seem to work with my TV. I'm going to keep percevering. Maybe I got the timing between presses wrong
    I'll keep checking here to see if any other info comes available
    All the best
  7. Pyara
    Pyara
    Was there any luck with this, as I too would like to tweek my 36PW9525...
  8. jezzpalmer
    jezzpalmer
    Jan 27, 2002
    22
