Philips 36/PW9618 Help Required
bonerp
Hi ya just joined after buying one of these. However in setting it up I have a greeny/blue pixel line along the top in all format modes. I have the engineers code and had a play but not too sure how to remove it!
I'm on NTL and found the footy scores and sky news text etc was missing off the screen so I have adjusted this in....just got this annoying line now!
Can anyone help with setting this box up?
Paul
C
Cynthia 7
Hi bonerp,
I have had the 36PW9618 television myself for about ten months now and I'm thrilled with it. Fortunately I have had no problems at all with this set. Bad luck with your greeny/blue pixel line.
Blind Lemon and rca gave the code 065296 then press the i+ menu button. Since I haven't tried this I'm not sure if it means press the i+ and also the menu button. Press menu button to exit. I know you have the engineer's code and have accessed this but I enclose this information in case it gives some help
I have Sky+ and I notice you have NTL. Does this line still appear on terrestial aerial whilst disconnected from anything else?
Good luck with getting this fixed.
